ReCap is not a professional tool, suitable for design professionals (at least not yet).
Never mind that ReCap requires cloudy credits to render photos in 'ultra megazord' quality in order to even download RCS file to be able to import into Civil 3D (when preview quality would be perfectly sufficient, takes exponentially less time, and requires no cloudy credits)... ReCap exporting to desired file format is in no way dependent on what level of detail the Point Cloud is rendered, and Autodesk darn well knows it... ReCap only supports Meters (not US Survey Feet?), which means we have to manually convert FT to M when entering survey settings during photo stitch, but also manually scale up the imported RCS file in kind, as Civil 3D Imperial session means nothing to Point Cloud Object Properties.
Further, one must remember to manually scale the ReCap Point Cloud BEFORE a Surface is derived, as scaling former after the fact has no dynamic change on the latter (which is sort of the point of using Civil 3D; dynamic relationships, no?).
I have access to ReCap through Infrastructure Deaign Suite (IDSP), yet have to spend supplemental cloudy credits in order to even download a file format that Civil 3D will accept - this is complete BS, as I require neither that level of detail, and the process to render at the higher 'ultra megazord' quality takes longer to render than it does for my survey crew to take actual TOPO (we tested some stockpiles this/last week, doing each manually getting TOPO, and GoPro photos, comparing volumes, times needed by crew and post-process, etc).
I'm deeply disappointed that Autodesk is removing useful functionality from Civil 3D, and introducing less efficient required steps to yield the same results.
This is counterproductive, it's counterintuitive, and the sort of backwards thinking that's going to make a lot of new BricsCAD + Transoft Site CEM customers.
This malarkey is the biggest disappointment of Civil 3D 2018 (for me), and not something I recall ever being announced during beta (perhaps I missed it?). We will not use tools that are web-dependent with our customer's data, as Autodesk accepts no responsibility, and provides us no security; therefore not acceptable per company policy, nor common sense productivity when internet line gets cut during construction down the road (happened twice this year already), etc
Add this to growing list of why we're never going to give up our Maintenance plan for Subscription.
All that said, QGIS is a great tool, and able to access ArcGIS GDB which is what I've needed it for previously (albeit rare I need to do that).
Cheers
