Announcements
C3D 2016 How do you add a drawing template
Hi can anyone help please _ in acad 2016 when I insert a template I usually right click on the layout tab then select "from template" which then directs me to the template folder but now for some unknown reason this no longer happens I am prompted in the command line to enter a file name ???
@BushW has edited your subject line for clarity: Adding a drawing template
M_c3d
try setting filedia to 1
Brilliant cheers worked a treat
BushW
Hello @Anonymous
Did @M_c3d resolve your issue with the great suggestions?
If so, please select the ‘Accept as Solution’ button if my post solves your issue or answers your question so, other Community members may benefit and thank you for doing so, and I'm here to help.
Best Regards,
Wendell
Wendell Bush
Civil Infrastructure Technical Support Specialist
