Broken Fields
Broken Fields
bryce_tennant2
Message 1 of 9
Broken Fields
bryce_tennant2
I have a drawing that I am linking fields to other sheet sets and every time I save the link goes to ####. I can browse to the other sheet sets and link the drawing just fine but on save it messes up. Any suggestions?
Bryce
Replies (8)
Message 2 of 9
F.Camargo
Bryce
@bryce_tennant2
Could you attached your file to take a look?
Fabricio
Message 3 of 9
bryce_tennant2
Attached is one of the files im having issues with.
Thanks for taking a look!!
Message 4 of 9
MMcCall402
I wonder if there is a limit on the number of characters within the path of a field.
Mark Mccall
CAD Mangler
VHB - Vanasse Hangen Brustlin, Inc.
Linkedin
Message 5 of 9
bryce_tennant2
Its the same amount of characters as the fields from their own sheet set. But thank you!!
Message 6 of 9
MMcCall402
Ok, it must have just been the way the file opened up without access to the sheet set it was referencing.
Does this sheet belong to the sheet set?
Mark Mccall
CAD Mangler
Linkedin
Message 7 of 9
bryce_tennant2
it belongs to a sheet set and the fields that are linked to that works fine. The other fields are linked to a separate sheet set and when i save, it changes to "*Unknown*" and puts ### in.
Message 8 of 9
Joe-Bouza
Im only guessing but if you are pointing to SSM fields the SSMAUTOLOCATE probably tells the field it should be part of the current Sheet set. I know the dialog lets you pick different SS but ... it does go kabluey doesnt it. Ive had the same experience
Joe Bouza
Message 9 of 9
bryce_tennant2
i have done this a lot in the past and it worked fine. Did you figure out a solution?
