I want to create section view at station 0+0.00 but i found something problem. I got my section view in STA 0+00 was not drew it should be. But not found that problem at another station. Just at STA 0+00. And then i check at my corridor and found that daylight bench was seen broken. Anyone can help this problem? Please
PS: I attached so many ss picture to anyone who wants helps me so they can undestand my problem
Thank you
Ivan
Check your existing ground surface! [your assembly at 0+000 should be placed with in the reach of the target surface. you may control or check it by your sample line at the same location if it may need a slight rotation or additional data for your existing surface]
