Broken alignment?
Broken alignment?
Message 1 of 8
Broken alignment?
Please see the image.. alignment is 'broken' yet grips still show up on the invisible parts.... and the stationing is right.....so alignment is still there and linked and working....yet it looks broken!!
Any help is much appreciated! Stumped my colleagues so far...
Thanks!
S
Replies (7)
Message 2 of 8
It looks like the "line segments" are either on a different layer and frozen, or have been switched to not display.
It might also be possible that the view has been twisted slightly into 3d.  This would then make the "Model" version of the display currect.
I am guess you have tried the first solution, if so I don't think I can help
Message 3 of 8
Check and see if there are any z elev attached.
Also check the display settings for curve and see what color
It's using.
Message 4 of 8
Hopng these was no twist to 3D... as for frozen etc.. i've checked this and none are... there is an alignment on the other side of the road.. and it is fine so I am really not sure what happened
Message 5 of 8
No Z elev. found. Line type is continuous...
Like I said in recent post.. alignment on other side of road is fine so I'm really confused as to what happened here!
Message 6 of 8
If you edit the alignment with the "Alignment Grid View" do the line segments show up?
Message 7 of 8
Hi all,
So I was tinkering with the properties... I have changed OBJECT STYLE to BYBLOCK from the CB it was on and this has fixed the broken line! There is a warning symbol for the curve or something. (This is a sidewalk on the alignment, not a centreline as the program thinks)
Thanks all!
S
Message 8 of 8
Hi all,
Thanks all!
S
