We are modifying an assembly created by someone which uses British kerb Hb2 125mm upstand with UKIE toolkit. The problem happens when we are modifying the sub-assembly pavement depths the kerbs moved away leaving a red circle at the assembly anchor point and other at a distance away with daylights. I attach screenshots of the issue.
Solved by gil.dalton. Go to Solution.
It should give an error message in Event Viewer hopefully telling what the problem is.
Do you have the UKIE Country Kit installed? This looks like Civil 3D is unable to load the BritishKerbs subassembly; a graphical representation of the sub subassembly is displayed until you edit it then Civil 3D shows the offset red circle for an error state.
You can get the UKIE Country Kit at here if you need it.
Gil Dalton
Gil Dalton
