To @muncle56
If you have shp, dbf, shx and prj files you can use MAPIMPORT to bring in the shapefile as AutoCAD entities, not as feature objects through an FDO connection. The command, as you already know, converts the shapefile into Cad line work. It sounds as though you've already used MAPIMPORT and have successfully brought in the line work. If you have also brought in the shapefile's attribute data during the MAPIMPORT procedure to accompany the cad line work, then you are halfway to your goal because you have object data. The remaining half is to use the OD to label the streets.
Once you have successfully brought in the OD, there are different ways to use it as well as to access it. In your case, you want to label the streets with their respective names. This type of labeling is a little tricky because each label's rotation will vary from street-to-street with the text angle tied directly to the street's line work. It's one thing to pull out the OD and create mtext but it's another thing to get the mtext to rotate according to each street's orientation.
To pull out the OD and use it as a source to label your streets, you can follow this >>video<< (the same video posted by the venerable @Pointdump) If you do it successfully your labels will not only appear, but they'll also be rotated correctly.
Chicagolooper
