I have run into an issue in a dwg where any and all blocks used in multileaders are unsnappable aside from the attachment to the landing of the leader and the insertion of the block itself. I have confirmed it is just this one dwg, I have tried pulling in multileaders from other drawings that I know work, I have tried importing MLeader styles from drawings I know work, I have tried importing blocks used in the multileaders that I know work, I have tried WBlocking the entire drawing, I have tried reinserting template files to see if it could overwrite whatever phantom system setting this is, I have tried opening this drawing on different computers, I have tried using Autodesk blocks and my Company's blocks, and nothing has worked and I am at my wits end on this.
Does anybody know what system setting or variable this could potentially be that needs to be fixed?
You can try the GRIPBLOCK system variable, but I believe within the context of a mleader, you can only edit the attachment point. You can see on the right here, I have a dynamic block with grips all over the place, but when I put that in an mleader, I only get the attachment point.
Looks like that isn't the solution to this, it still keeps the same issue and the grips don't appear unless I explode the leader and have the block alone.
