I got a dwg sent to me that uses blocks to represent a house with assigned customer number. Block is just a circle with the customer # in it. I put cogo points on these blocks because I need lat/long data from them. I can't change the customer numbers but I need the point numbers to match them because im exporting the data to excel...I've already got the points in so is it possible to make the point number match the block text without manually pulling up the point list and just typing in the customer #'s as point numbers https://9apps.ooo/.
I'm new to civil 3d
Hi @chinyushiba,
Welcome to the Autodesk Forums.
Please post your drawing. Let's see what you've got.
Dave
Dave Stoll
Las Vegas, Nevada
use DATAEXTRACTION to extract the blocks to excel.
make sure to include x,y, House#.
rearrange and add: House#, y, x ,0, house
use this to create your cogo points by PNEZD
set the display to show lat long
Joe Bouza
