- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am currently developing a linear design (50 km in length) where elevations are specified at 1 km intervals, with each kilometer having a distinct elevation value provided in tabular form.
My goal is to generate surfaces for each kilometer segment and export them as a combined LandXML for volume calculations in external software (either per km or for the full extent).
At present, my workflow is as follows:
- Create polylines representing the north and south extents of each segment
- Convert these into feature lines and assign elevations
- Add them as breaklines to a surface
- Apply a boundary and then create cropped surfaces for each kilometer in separate drawings
However, because each kilometer has a different elevation at its start/end, the resulting surfaces introduce slight slopes between segments. My current workaround is to offset the start/end lines by 1 mm to prevent adjacent surfaces from interacting.
This approach is quite cumbersome, particularly when working at very small tolerances (e.g zooming in to join polylines accurately).
Is there a more efficient or robust method within Civil 3D to:
- Maintain discrete, flat surfaces for each kilometer segment with differing elevations, and
- Export them cleanly for LandXML based volume calculations?
Any guidance or alternative workflows would be greatly appreciated.
Processor Intel(R) Core(TM) i7-14700HX (2.10 GHz)
Installed RAM 64.0 GB (63.7 GB usable)
System type 64-bit operating system, x64-based processor
