Band Set Style Changes on Import
02:11 PM
I have a template set up with a band set style that works for our profiles. I have done a purge and audit to make sure template is clean and no problems. When I import the band set into another drawing the major and minor interval settings change in the imported band set style. This happens regardless of how I do the import - drag and drop or use Import from the Manage tab - or whether I overwrite an existing band set style in the drawing or delete the band set and all references to it first, then import the style from the template, or whether I import only the style and not the settings that reference it or just the style alone.
Any solution to this, or do I just ignore this style and manually adjust these settings every time?
