Automatic widening formula according to AASHTO 2011
I need to apply curve widening according to the formula(s) of AASHTO standard (2011) and taking into account a WB-33D vehicle. The widening applied by Civil3D, with automatic procedure command, is really higher than expected, resulting in a very wide road platform. It occurs selecting also other standard vehicles.
Checking the AASHTO standard file adopted by Civil3D (file: _Autodesk Civil 3D Metric (2011) Roadway Design Standards.xml), the standard formula (derived from formula no. 3-34 of AASHTO) is reported like:
formula="{n}*({w}+{r}-sqrt({r}^2-{wl}^2)+{c})+({n}-1)*((sqrt({r}^2+{A}*(2.0*{wl}+{A})))-{r})+0.1*({v}/sqrt({r}))- {tw}"
At first glance the formula, in particular the first portion derived from formula 3-31 "U", seems the one reported in AASHTO, instead the first element {w} is defined in the same Civil3D file as "{w} - nominal lane width or normal lane width edge of traveled way". Instead in the AASHTO 2011, this term, named as {u}, is defined as "track width on tangent".
I don't know if it could be the reason behind the wider widening on curve than expected by me (and manually calculated), however is there someone who have experienced the same problem or knows which could be the solution to that?
Thanks!
