Automatic Structure elevations from Feature line
KFilion
Message 1 of 8
KFilion
I was wonder if anyone can point me in the right direction to create an automatic label. I would like a piece of text to read the Highest elevation and Lowest elevation of a feature line so I can figure out FFE and USF elevations with a formula. So far I have a feature line for lot perimeter which is link to my FG design surface.  I'm hoping I can use something pre build in Civil 3d rather than using dynamo.
what tool / label can I use to be dynamically linked  to a feature line?
Replies (7)
Message 2 of 8
jmayo-EE
I don't believe there is any OOTB solution for this except Dynamo. C3D labels do not have the ability to perform test conditions that would allow you to ID a high or low point to report.
John Mayo
Message 3 of 8
how hard is it to look thru the elevation editor for feature lines and spot which elevation is highest?
Message 4 of 8
KFilion
very hard if your being sarcastic, I wanted a label to be linked to a feature line and automatically show the elevation and then I can apply a formula to that highest elevation.
Message 5 of 8
KFilion
Message 6 of 8
not being sarcastic, just exasperated by the age of instantness.  but i just thought of a visual method that would take two seconds to see the highest point.  use quick profile and pick the offending feature line.
Message 7 of 8
jmayo-EE
It’s not very fast if you have many flines with hundreds of pi’s and no sorting ability. This task can easily lead to hair loss. 🙂
John Mayo
Message 8 of 8
KFilion
yeah its fast if you wanted to see one or two elevations but not when you have 50 to 200 feature lines on a given project.
