Automated Widening on Offset Alignment Based on Curve Radius — Start at Spiral In, Peak at Curve In, Taper at Spiral Out
Beka_Tchigladze
Advisor Advisor
Beka_Tchigladze
Hi everyone,
I'm trying to implement automated widening on an offset alignment in Civil 3D, based on predefined curve radius values and corresponding widening widths. I’ve already created a custom widening table in the Design Criteria XML file, where each radius maps to a specific widening value.
What I want to achieve is the following:
• Start the widening exactly at the Spiral In point
• Gradually increase the widening until it reaches the maximum value at the Curve In point
• Maintain the maximum widening through the curve
• Then begin tapering down at Spiral 2 In
• And finish the taper at Spiral 2 Out
So far, I’ve managed to define the widening widths per radius, but I can’t figure out how to control the widening transition along the alignment geometry — especially how to tie the widening start and end points to the spiral geometry.
Is there a way to do this using the Design Criteria file alone?
Any guidance or examples would be greatly appreciated.
Thanks in advance!
Beka
Beka Tchigladze
Road/Highway Technical Designer
AEC Collection/C3D 2025
WIN 11 64 PRO
Predator Helios 18, Intel Core i9 14900HX, 32 GB
NVIDIA RTX 4080, 12 GB
YouTube--->Linkedin
andrewpuller3811
You should check into the transition lengths under the Superelevations Tables node.
You might also need to at the superelevation attainment methods.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 11
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2023
Beka_Tchigladze
No luck 😞
Beka Tchigladze
WIN 11 64 PRO
YouTube--->Linkedin
