AUTOMATED ANNOTATION
Message 1 of 10
Is there a way to set up autocad to automatically annotate a line after it is drawing.  Meaning labelling bearing and distance automatically.
Replies (9)
Message 2 of 10
jmayo-EE
If you make them parcel lines you can. Just check Automatically Add Label Lines.
John Mayo
Message 3 of 10
MMcCall402
Note, this only works if the selected objects form a parcel.  If they're just open line work then no labels are applied.
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
Message 4 of 10
Joe-Bouza
My Velcro Sneakers make up for the lost time 😂
sorry couldn't resist.  Use polylines and label multiple segments
https://autode.sk/2B9WrnA
Joe Bouza
Message 5 of 10
CAN THIS be done with open line work?
Message 6 of 10
ChicagoLooper
You can label your line work. The labels do not automatically appear. You is still have to use your mouse to select which lines get labeled.
Chicagolooper
Message 7 of 10
Joe-Bouza
Use polylines
Joe Bouza
Message 8 of 10
jmayo-EE
I think what we are all saying here is that the product, as-is/OOTB will not automatically label lines either while being drafted or after drafting globally.
John Mayo
Message 9 of 10
jmayo-EE
Is this on the Idea Station? Should be.
John Mayo
Message 10 of 10
ChrisRS
You cannot "Automatically Annotate a Line" that you draw.
     -  However  -
You can "Automatically Line an Annotation" that you place.
Create a "Line between 2 Points" label, that includes a line.
Other options:
Include a circle block at the start and arrow head block at teh end for a directed distance (ray) label.
Make the bearing visibility false and add arrow head block at start and end for a mock dimension.
etc.  (These labels automatially scale but do not have the full capabilities of annotative components.
Limitations:  The label text components and line component will be on the same layer.
If using wide lines, true type fonts may be work better than stick fonts.
Christopher Stevens
