Is it me, or has the AutoDesk RSS Support feeds been broken for 6-months now?!?!
http://rss-support.autodesk.com/subscription
If I click the link above the page errors out. In my feed reader that I setup a long time ago, I see the new support topics come up but if I click on them to read the page errors out.
Anyone having the same issue??
Solved by AlmasSuljevic. Go to Solution.
Hi mspatz,
I am not having the same issue you described but I am using RSS feeds withing Civil 3D and inside of Outlook. It all works fine. There may be an issue with your RSS reader. You may test it by adding custom RSS feed to Civil 3D and see if that helps. Here are the steps for reference: http://beingcivil.typepad.com/my_weblog/2010/09/adding-being-civil-rss-feed-to-civil-3d-2011.html.
Good luck!
You're right - sort of. I guess never tried to read the feeds from work. I use Google Reader and if I access from work everything works fine. It must be something with my home - comcast - connection or router.
I can't believe I have never tried to access from work!! Man I'm productive...
