Autocad project task - Feature Line
F.Camargo
F.Camargo
Hello friends!
How are you?
I am studying about some tools on autocad civil...
I am struggled using feature line, and I need some help. It's a simple task on this dwg file
Does anyone could help me to solve it, please?
I've already tried it, with no success.
Thank in advance
Fabricio
Replies (22)
Joe-Bouza
What’s the question ?
Joe Bouza
F.Camargo
I think I will delete this post. I couldn't do this project (example) modeling a parking lot using only feature lines.
I was looking for a workflow to learn how to do that.
I couldn't find on youtube too.
AllenJessup
There could be many solutions. I'd create a Featureline along the centerline of the lot between the two entrances where you need to match the existing grade. That will show you how the grade through the lot might flow.
I like to grade to the CL. So I'd grade out from the Center Featureline out a positive 2%. The exception would be at the throat of the entrances where you also need to match existing elevation with the bottom of curb.
Others like to grade to the curb line so they would grade out at negative 2%. There are many possible solutions in the real world that would depend on local regulations, existing ground, finished floor elevation of the building the lot may service, etc.
Allen Jessup
CAD Manager - Designer
Joe-Bouza
There is a workflow @AllenJessup  is on point and as said many ways to do. I’ll look at the file shortly
Joe Bouza
F.Camargo
@AllenJessup
Do I have to start creating a feature line from the entrances? Like this?
I am used to work with aligment. I think it is easier!
But I need to do by feature lines.
AllenJessup
Pretty much. I'd make a complete Featureline through the lot to grade from. It look like you're going to have to do some editing to the grades to make the requirements.
You'll want to use the grades you create to create Top and Bottom of Curb along the lot. It's not specified in the requirements but you might want to see if you can get the curbs close to the existing elevation.
Yes. An alignment and corridor would work as well. But I'd use Featurelines for such a small lot.
Allen Jessup
Joe-Bouza
This is how i woud begin.
As @AllenJessup  suggest working from or to a center is a good idea.
1. alignment and profile  down center of parking bays
2. 50 foot section to visualize existing
3. create a temp surface off the alignment and profile
4. elevations for temp/ TC relative to temp +0.5
5. tie driveways into existing
6. tie tc to existing
Joe Bouza
F.Camargo
Thanks my friend.
Give me some hours to understand and trying to do it by my self too. 😄
It is a pretty many steps.
Thank in advance
Joe-Bouza
Take your time
actual doing is pretty simple
Joe Bouza
AllenJessup
@Joe-Bouza
That's a good workflow. However the task was to grade the lot only using Featurelines. You could cheat and use an alignment and profile then extract Featurelines. But I don't think that matches the spirit of the exerecise which seems to want to get you familiar with Grading with Featurelines.
You could also use Gradings from the CL Featureline. But again.....
Allen Jessup
F.Camargo
@Joe-Bouza
I am stuck on step nº 3;
I don't know what to do next...
I've seen a surface in your file "Grading Group 1", it is a surface from feature line. Is that a temp surface on step 3?
I don't understood why I create a aligment and profile the first.
Fabrício
F.Camargo
Yes my friend.
I am trying to using only feature lines.
Joe-Bouza
The alignment and cross section are an analytic tool so you can determine the direction and magnitude to grade. ( note we are following grade
using the profile (feature line) of the parking area I created a typical cross slope of 2% this is then reviewed on the section to see if confortable with the preliminary cut and fill.
then the parkin FL are linked to the temp surface to form the FG break line ( now they are dynamically linked to the temp surface and the center profile/ cross slope
The temp surface was created with a grading off the PGL extracted from the alignment. the grading was set to 2%--2% ( this can be easilt revised if desired and the parking FL above with update accordingly
Joe Bouza
Joe-Bouza
lol... that task was use feature lines there was no dictate as to how they are created 😅😎👍
there is no reason to ignore Ill post a different FL workflow shortly - one of my favorites
Joe Bouza
Joe-Bouza
@F.Camargo  & @AllenJessup
I know you said no corridor too, but this is a different kind of corridor made of feature lines
Joe Bouza
F.Camargo
Hi @Joe-Bouza
How are you?
Have you attached a file with other solution?
I couldn't see it
Fabricio
Joe-Bouza
Oops! My bad. I’ll have soon
Joe Bouza
Joe-Bouza
Hello Fabricio
here the the special corridor technique.
IMHO this is the most stable use of FL
Joe Bouza
