error of creating profile from file
This widget could not be displayed.
I'm trying to create a profile from a txt file but I keep on getting this error message ''Input file has invalid geometry'' .
the file format is as (Station elevation curve length)with space-delimited
Any assistance will be highly appreciated.
I have attached the text file,,,
Accepted solutions (4)
Replies (7)
no text file attached
ChicagoLooper
Have you seen this 6 minute >>VIDEO<<?  It explains how to create a profile from a file.
Source: Jerry BartelsSource: Jerry Bartels
Chicagolooper
Joe-Bouza
Verify the stations are in order.
AND the txt file is saved as MSDOS
if it is saved as UTF it will not work
Joe Bouza
Jeew-m
In this case the file format matters most.
Checkout with THIS whether your one complies with the standards.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Hi azrdgldr
sorry for that
the file attached here,,
wfberry
You have two 150' vertical curves which means 75' each direction.  You only have 20' between the PIs.
Bill
kanishkpadhi
I am facing same issue too. Have tried internet solutions and also all the steps mentioned above but still getting "Input file has invalid geometry". Can someone please help? Attaching the file for reference
