AUTOCAD CIVIL 3D for houses 3D plan(Beginner)
Hello all. I'm assigned to teach Construction management students AUTOCAD CIVIL 3D. I would like to check if they can use this program to create a 3D plan for houses, or is it just for surveying, piping and roads. I want them to learn it all.
Thank you.
rkmcswain
Civil 3D is a set of survey and civil engineering tools built on top of AutoCAD Map 3D, which itself is built on top of AutoCAD.
Yes, you could create a 3D house plan using the features and commands in AutoCAD, but there are better tools for this task, depending on how detailed you need the house plan to be.
Are you just looking to make a 3D box with a roof on top, or do you need a full detailed home?
Thank you for the reply. I'm looking more for dorm rooms design, similar to pictures below
DarrenP
you may want to look at Revit instead
DarrenP
Thank you.
I thing Revit and 3Dmax is better for such details
Hi there, i need someone help me to desing layout for houses by using civil 3D auto desk
thank you
