AutoCAD C3D 2014 Fatally Freezing at least 5 times a day
Something is up with AutoCAD on my computer. I will give you all the information I have, and hope you can give some good suggestions. This isn't the first time my autocad has frozen/crashed several times a day requiring restarts and many lost hours every week, but I thought I had fixed it for good until it came back this time. The issue last time was a system default that was requiring AutoCAD to regen layouts every time I selected one. This issue is a lot harder to narrow down, but I will post the issues, and my hardware specs below. I do not believe it is a hardware problem, my computer is the best in our office on paper, yet my coworker's "inferior" computer never has had the problems that I have, nor do I when I use her computer.
Issues:
  • "Error Occured During Save..." message a few times a day. Even when I run recover.
  • Disappearing surface only on my computer. My computer completely forgets what is in the surface, but the surface name still shows up in the toolspace. It magically reappears on other computers.
  • Selecting blocks freezes my computer until I end AutoCAD, but everyone uses these same blocks
  • Undo commands freeze my computer until I end AutoCAD
  • Join completely wrecks my computer, even when lines are flattened, exploded, then joined
  • Copy or Move will "drop" selected items and they disappear when I pan while in command.
  • System defaults are constantly changing, some that I notice more than others are pickfirst, filedia, snapang in mid command, and the regen layouts default I mentioned earlier.
These issues almost never occur at the same time, but it only takes one to incapacitate my computer. This is not an exhaustive list, and I will update it as a notice more issues.
Hardware:
CPU- Intel Xeon CPU ES 1067- v3 @3.10 GHZ 64bit OS
RAM- 32 GB
Graphics Card-Nvidia Quadro K2200
Please give me any ideas you have, even if you aren't sure. Thank you!
Replies (7)
ToddRogers-WPM
Thanks for listing your hardware. However, this could possibly be due to your OS. Are you using Windows 10? If so, 2014 is not supported.
Todd Rogers
Thanks for the response. I am running Windows 7 Professional. Is that
supported?
ToddRogers-WPM
Yeah, that's definitely supported. Have you tried resetting user defaults?
Todd Rogers
I have repaired it from the control panel programs tab, and manually
deleted customization files. I can not reset it like I have seen people do
online through the start menu because it won't give me a prompt to. Below
is an example of my start menu.
ToddRogers-WPM
Ok, no problem. Go to Start>Run, and type in REGEDIT. There, navigate to HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R???\ACAD-????:409.
I can't remember what the numbers are for 2014, but if you click on the .... :409, it will tell you on the right, similar to pic below...
Once you have verified that it is 2014, then right click on the ACAD-????:409 and delete it. Make sure C3D is closed before you do this. Then restart C3D and it will rebuild your profile. Should work fine after this.
Todd Rogers
ToddRogers-WPM
Also, keep in mind, any customization will be lost and have to be re-customized. That repair from the Control Panel rarely ever fixes anything.
Todd Rogers
Seems to be working well for now... Thanks for the help!
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
