Good morning, I have a general question in regards to Autocad Civil 3D backup files. I recently tried to open a backup file and was prompted to select a software in which to open the (.bak) file, I went ahead and selected standard Autocad 2d to open the (.bak) file. However, the back up file did not open. In addition, all of my backup files now appear as a standard Autocad 2D file. My question question is
1. How do I open up AutoCad Civil 3d (.bak) files
2. How do I convert the (.bak) files from showing the standard AutoCad 2D symbol to the original (.bak) file icon.
Thank you!
Solved by user181. Go to Solution.
Change the file extension to .dwg and then AutoCAD will open it.
