AutoCAD 3D 2019 pipe network issues
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I switched to Civil 3D 2019 and have started finding serious issues with pipe networks that I have not seen before. We have noticed we will create pipe networks and set all the inverts for design. We will save and close the drawing. When we re-open the drawing, the pipe inverts are all reset to what appears to be the pipe rule set. We have tried un-checking the use values from rule set box under pipe properties and are still having the issue. I started thinking that it has something to do with our data referenced surface. I re-adjusted a few pipe inverts as a test, synchronized the surface and the inverts I adjusted all reset! Is there a new setting that I am not aware of? Has anyone else seen this yet?
