AutoCAD 2019.1.2 Update is now available for Subscription customers through the Autodesk Desktop App or through the account page.
Important: The AutoCAD 2019.1.2 Update includes all the updates previously released for AutoCAD 2019.
Security Update: As part of Autodesk’s ongoing efforts to provide the best security possible to our customers, we are proactively applying security updates to our products. The 2019.1.2 Update must be installed by October 17th, 2018, in order to maintain access to the following features:
- Plant Collaboration Project for the Autodesk AutoCAD Plant 3D toolset;
- Autodesk Rendering;
- Shared Views
Applying Updates
AutoCAD Updates can be applied to AutoCAD including specialized toolsets installed standalone as well as Autodesk Civil 3D and Autodesk Advance Steel. You can install the AutoCAD update in addition to any applicable updates for your toolsets, products and services listed below.
AutoCAD products and services:
- AutoCAD 2019
- AutoCAD Architecture 2019 specialized toolset
- AutoCAD Electrical 2019 specialized toolset
- AutoCAD Map 3D 2019 specialized toolset
- AutoCAD Mechanical 2019 specialized toolset
- AutoCAD MEP 2019 specialized toolset
- AutoCAD Plant 3D 2019 specialized toolset
- Autodesk Advance Steel 2019
- Autodesk Civil 3D 2019
After applying this update, the Product Version in the About box will be listed as P.161.0.0 AutoCAD 2019.1.2. If you use one of the other products above, the Built On version will be listed as P.161.0.0 AutoCAD 2019.1.2.
Problems Reported Through the Customer Error Reporting Utility
General
- Crashes when repeatedly loading and unloading the Standards ARX files.
- Crashes when pasting from the clipboard as an OLE object.
General Update Content
Display
- Arcs and circles within dynamic blocks display correctly at large coordinates.
- The Unisolate operation on layers is faster.
Xref
- Xref highlight works when using the arrow keys to select the Xref from within the External References palette.
General
- Object selection completes when the mouse is still moving.
For additional detail, please see the attached Readme file.
John Vellek
