- Mute
- Permalink
- Report
We are upgrading an existing, superelevated road and need to control superelevation using profiles. We have a custom shoulder subassembly that reads the superelevation of the road just fine. I thought we could simply use the output parameters from the lane subassembly to define the slope of the shoulder, but I can't assign output parameters to the input parameters of the custom subassembly.
The custom subassembly works as expected, except for when we need to reference parameters from other subassemblies. I've attached a screen shot showing the assembly with our custom subassembly and the Input and Output values are blank. I can assign output parameters to input parameters for other subassemblies in this assembly.
Did we miss a setting in Subassembly Composer 2015 that is required to enable this functionality? Any tricks, or things we should not have done?
I've attached the PKT file, in case it helps.
