Assign Predefined Property Sets To Corridor Solids Automatically
Beka_Tchigladze
Advisor Advisor
Beka_Tchigladze
Hello, I have predefined property sets for corridor and also in Apply To Tab I checked Corridor, Yes I can Assign property set to corridor, but When I want to extract the solids, It does not show the Custom Property sets which I already Predefined How to force civil to assign predefined property sets to corridor solids?
What Solution Could you suggest?
Beka Tchigladze
Road/Highway Technical Designer
AEC Collection/C3D 2025
WIN 11 64 PRO
Predator Helios 18, Intel Core i9 14900HX, 32 GB
NVIDIA RTX 4080, 12 GB
YouTube--->Linkedin
cwr001
From the top of my head, not sure if I recall correctly:
The "list" of available PSets only get's populated after the fist extraction. So try to extract once (just with the defaults), delete and extract again.
Not sure if that's it, but I remember something like that.
Beka_Tchigladze
Ok, i have solved the problem, it is impossible to give predefined property sets to the corridor, but i build some property sets based on the corridor stock programmed property set for ecample use corridor shape information or corridor name and i apply them after creation of thr 3d solids from corriodor. Since the solids already had all the corridor information in the prop sets i applied my custom sets  and thay work,
Beka Tchigladze
WIN 11 64 PRO
YouTube--->Linkedin
