assembly not showing up in section views
caldwellkenya73
caldwellkenya73
I am not sure what is going on, but my assembly is not showing up in my section view.  The corridor is created, but it's not showing up in the section view?
SoaresASBCAD
@caldwellkenya73
If the corridor is built but the assembly (corridor section) is not showing in your section views, there are several common causes. I'd check them in this order:
Verify the corridor has been sampled
If the corridor wasn't added to the sample line group, it won't appear in section views.
Go to Prospector → Alignments → Sample Line Groups.
Expand Sections.
Confirm your corridor is listed as one of the sampled sources.
If not, right-click the Sample Line Group → Sample More Sources and add the corridor.
Rebuild the corridor
If you've modified the assembly after creating the corridor:
Right-click the corridor → Rebuild.
If Automatic Rebuild is off, turn it on or rebuild manually.
ASoares
Joe-Bouza
Verify the base line the section viewer is reading
Joe Bouza
andrewpuller3811
Another item to check is if the corridor is checked as a section to display in the section group properties.
To check this -
Select a section view
Right click and select Section View Group Properties ...
Select the Section tab
Ensure the corridor is checked.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 11
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2023
ah.mgahed
Please check the Sample Line Group sources.
Go to:
         Sample Line Group > Sample More Sources
Then make sure the Corridor and/or Corridor Surface is selected and added as a sampled source.
Also check:
Section View Properties > Sections tab
Make sure the corridor section is listed and has a visible section style.
The Assembly itself will not appear directly in the Section View. You need to sample the Corridor or Corridor Surface first.
ahmed mgahed
