assembly for high cut and fill section
sahatsuparng_pip
sahatsuparng_pip
Road design on the mountain
There are some of my section view and my assembly
I don't know what is going on with my section It should finish with the cut but why there is the fill area happen and some of my section there are also have the cut area while it should finish after the daylight see the existing ground
ecfernandez
Hi @sahatsuparng_pip, welcome to the forums. I invite you to share your file to give it a look. Meanwhile, you can check the following:
1. Make sure you compare the correct surfaces in the computation criteria.
2. Make sure your comparison/corridor surface has a well-defined contour. It looks like your surface needs some refinement in this aspect Erase all the triangulation beyond the corridor limits and compute the volumes again.
Please let us know your thoughts. I hope this helps
Best regards!
Camilo Fernández
P.Eng | Transportation
LinkedIn
sahatsuparng_pip
I appreciate that your answer help me a lot. I checked the surface and erase the triangulation of surface and corridor's surface the over cut and fill areas are better but there are some error areas remain and miss ditch on some layers of cut and fill as shown in the figure
ecfernandez
Hi @sahatsuparng_pip, thanks for letting us know. What you refer to in your last post is caused by the fixed-length links in your assembly (I circle them in the following image).
 When the cut/fill conditions are met, your assembly places this geometry, and since the length of the links is considerable, it ends up out of the terrain, making your daylight go down looking for the surface and creating the fill portion you see at the end of the section view
You can solve that problem using any of the following options:
1. Open the section editor. Go to that specific section and edit the geometry of the fixed link to make it fall within the terrain. For example:
In this example, I am located in section 0+005.00. I opened the parameter editor and edited the cut slope from 1.0:1.0 to 0.5:1.0. This edit will be true just for that section, overriding the default values I assigned in the assembly before building the corridor.
2. If you are using Civil 3D 2023.2 or newer, use corridor transitions to edit the geometry of that problematic link for that specific region. If you want to know more about that, visit this link: Model Civil 3D Corridor Transitions Using Any Subassembly
3. Create a custom subassembly with a dynamic dimension for the height/length of that link, so you don't have to worry about it. This can be done with Subassembly Composer.
4. Ideate a better way to arrange conditions or sectorize your corridor so you can place a different subassembly with a lower height/length for that link so the end is within the terrain and the cut slope is correctly generated.
I hope this helps. Best regards!
Camilo Fernández
LinkedIn
