Hi Everyone,
I'm hoping I can get some help with Assemblies... Does anyone know how to add a ditch to the bottom of a 2:1 slope where it matches the existing? Please see the PDF I've attached, what I want to do is in red.
With S.A.C. add a point and forthe geometry type use slope to surface. You'll be able to set your 2:1 slope. Afterwards you can add more points / link to create your ditch.
You'll need to target your surface when making the corridor.
There might already be some link to surface from C3D if you are not familiar with S.A.C. and don't want to deal with it 😉 (I prefer to make my own subassemblies with S.A.C.)
There's no need for SAC. You can use a generic SlopeToSurface link to target the existing surface, then a collection of generic WidthAndSlop links followed by another SlopeToSurfaceLink that again targets the existing surface.
Don Ireland
Engineering Design Technician
With the exception of all the decision stuff (If statements, switches etc) you can do with generic links just about anything you can do with SAC. You just won't have ONE SA like you'd have if you were to use SAC.
I for one try to avoid SAC if at all possible because of the workflow involved.
Don Ireland
