So, you downloaded and installed the free ArcGIS for AutoCAD plug-in. Good for you. You can print World Imagery by doing this:
1. ArcGIS Tab=>Project Panel=>Coordinate System Icon=>Assign Option=>Search for, Select and Assign your coordinate. Then go to Contents Panel=>Contents Button=>ESRI Contents palette will appear on the left.
<< Note: you must ASSIGN your modelspace coordinate system using this icon IN ADDITION TO the coordinate system you have already assigned to your drawing. This means assigning the CS twice: Once using C3D/M3D and again using the ASSIGN option in the ArcGIS tab of the ribbon. The ArcGIS for AutoCAD plug-in, for some bizarre reason, cannot understand Autodesk CS assignment. >>
Image-1
2. Center your view in modelspace. Zoom-in or zoom-out as needed. Next, right click your Imagery Layer, e.g. World Imagery then click EXTRACT from the shortcut menu.
Image-2
3. After a few seconds, you'll get the option to SAVE your image in png format. The extents of your image will be the image as displayed in modelspace. Name and save your image. You don't need to insert or attach this image because ArcGIS for AutoCAD will insert for you. The image will be placed on the current layer as an xref and will appear in the external ref palette. This saved image is printable.
<<Note: you may also perform EXTRACT from a layout tab. The extents of your image will be the image as displayed in your viewport.>>
Image-3
As you already know the image layer shown on the ESRI Table of Contents will not print. You may, if you wish, uncheck the image layer in ESRI Contents. If you wish to print, then the image layer must be on and thawed.
Chicagolooper
