Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Arc by tangential azimuth + radius and arc length?
sgleadleD3EMJ
sgleadleD3EMJ
Is it possible to define an arc by the tangential azimuth going into the curve, the radius of the curve and arc length? I can do it with the radial arc command in the traverse editor but there are times when I'd rather not use the traverse editor. I can also traverse (line by azimuth) into the radial point and back out but I'm hoping there is a way to directly define the arc.
Jeff_M
Draw a line at the tangent azimuth, then use the AeccCurveFromEndOfObject command.
Jeff_M, also a frequent Swamper
sgleadleD3EMJ
You're the best Jeff! Thanks again.
