Anonymous Blocks
This widget could not be displayed.
Anonymous Blocks
I would like to be able to rename or redefine Anonymous blocks in any version of C3D.
Any suggestions?
Replies (12)
AllenJessup
I don't have a drawing that I know has an anonymous block to test. Have you tried RENAME?
Edit: Looks like it should work https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Rename...
Allen Jessup
CAD Manager - Designer
The ones I have got look something like *U*...
And there are over 150 of those!
I do not think they show up in Rename or Qselect!
Some civil objects exported to 2D AutoCAD turn to anonymous Blocks!
usually, I receive them from some client!
TerryDotson
If you want to eliminate guessing on the part of those who reply, attach a .DWG of the "anonymous blocks".  I'm guessing they are (rather were) CogoPoints and can be converted back in a second with the right tools.
Here it comes!
Let see if there is a way to handle these blocks!
Thanks!
Pointdump
Akbar,
Attached please find the Unanon.lsp which I got from >>>Here<<<. Command UnAnonall will change the names of your anonomous blocks to "TempXXX". Then you can edit them as normal blocks.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Thanks! It worked!
Is that possiable to keep the attributes too?
Pointdump
Akbar,
"...keep the attributes too?"
I don't know. Your Anonymous Blocks didn't have any Attributes to start with. I'd never even heard of an "Anonymous" Block until your post.
Dave
Dave Stoll
Las Vegas, Nevada
Thanks anyway! I am going to use the LISP!
vergaelen.jasper
You can also solve it like this:
- select anonymous block, then right mouse button
- select "Copy Block Definition and Assign"
- select "no" in the next window
- In the next window you can rename your block
After This the block is like any other normal block and you can edit it in block editor.
Hi!
I am running older version so this function is not available!
louise.otto
Community Visitor
Community Visitor
what a great script, thank you so much!
