Why does my viewport look like this? My annotations are too big when I'm entering viewport. Can layout my job properly. Can someone help me? I dont know what i've been done lately on my software lol
Solved by olivarrain. Go to Solution.
Solved by Udo_Huebner. Go to Solution.
Solved by igi_pop. Go to Solution.
Solved by lim.wendy. Go to Solution.
Hi @olivarrain,
Welcome to the Civil 3D forum and thanks for posting. Be sure to check the Plot Scale, Annotation Scale and Standard Scale
Hello there!
Select your viewport, in the properties pane there's "annotation scale" and "standard scale", set them to what suits you and you're done. Keep in mind, setting the anno scale automatically changes the standard scale in the list too match, keep that in mind.
Cheers,
Iggy
Your annotation scale is almost at zero. Click on the white arrow (where my red arrow points) and switch first to 1:1000 scale, then ZOOM to Extends, and everything should be readable again.
