My firm currently uses a two different tree symbols. One representing a deciduous type of tree, the other a conifer. All of our symbols have the diameter size (text) shown next to the trunk. My question, is it possible to make the text annotative without making the tree annotative? I have often went back and forth with other drafters about this issue. Some people believe the tree's actual size representation on the sheet is unimportant. I disagree tremendously as it is part of the landscape such as a road width or building dimensions, and therefore should be placed respectively. Can anyone help with some suggestions?
Solved by tcorey. Go to Solution.
Edit the Point Style. On the Markers tab, change the Size option to Use size in absolute units. You might have to play around with your size to get it where you want it, but scale changes won't affect it.
The label is a component in the point label style and will continue to reflect drawing scale changes.
