Hello.
Besides creating a custom command, is there a way to annotate the slope between two points in a plan view?
I want to do the same as Analyze > Inquiry panel > List Slope, but instead of just showing the slope, I want to annotate in the drawing.
Greetings from Paraguay.
Claudio Bogado Pompa.
Solved by MMcCall402. Go to Solution.
Thank you for your answer.
In plan view I did find the option to annotate the slope in the XY plane, I want to annotate the slope in the vertical plan that contains the two points.
Is that possible?
There is a Line and Curve label type of 'Line between 2 Points'. You can use this label type along with a snap setting to the points as a Node and it will pick them up as x,y,z coordinates. You can set up the label style to display the slope between the two selected locations.
Note, this label is not dynamically linked to the points. Its just a label you can snap to two different locations and label information between them.
