Civil 3D Forum
Analysis was unsuccessful but no error in output report
6 REPLIES 6
aphealyVB233
511 Views, 6 Replies
I am running tests in SSA. The analysis runs fine until I try to add a drainage basin in the drawing. Then, upon running an analysis, the dialogue box states "Analysis was unsuccessful. Review output report for further details." But in the output report, there is only design data, no error reports.
Thanks in advance!
Labels (1)
6 REPLIES 6
jmayo-EE
in reply to: aphealyVB233
You need to post the end of the asci file. That's where the errors will be listed.
John Mayo
aphealyVB233
in reply to: jmayo-EE
There are no errors listed, just the duration of the analysis.
jmayo-EE
Confirm with the autodesk desktop app that ssa is fully updated.
Post your ssa file for better results. 🙂
John Mayo
aphealyVB233
When I try to attach the .spf file the forum says : "The attachment's testt.spf content type (application/octet-stream) does not match its file extension and has been removed."
Edit:
jmayo-EE
In the Analysis Options dialog set your reporting and routing time steps to 5 sec. Note the different unit format in each field.
Check your junction inverts.
John Mayo
aphealyVB233
Thank you, that is very odd because the analysis ran fine with the junctions before I added the subbasin.
Rail Community
