Civil 3D Forum
Alignments / Profiles Causing Problems at Origin
2 REPLIES 2
twilkinson
201 Views, 2 Replies
Hi all,
I've completely run out of ideas on this problem, so I'll bring it to the boards.
I have a drawing file with 1 Centerline Alignment and 18 Miscellaneous Alignments. 12 of the Misc Alignments have profiles and profile views.
What's happening:
- Zoom Extents works as if there is something at the origin. Meaning, ZE will include all of my linework, xrefs, and 3d objects that are out at approx (6000000,1980000)
What fixes the problem:
  1. Delete all of the alignments -OR-
  2. Delete all of the profile views
What doesn't work:
  1. Deleting any other combination of alignments/profile views
  2. Deleting the profiles themselves (whether surface profiles or created profiles)
  3. Any of the usual  steps:
  • Turning on all layers and looking for an object at 0,0
  • Audit (never any errors)
  • Purge (completely clear)
  • Purge Styles
  • Purge and Audit all over again
  • Save a copy then purge and audit again
  • Audit and purge all xrefs (no problems)
  • Detach all xrefs
  • _mapclean
  4.  Turn all alignments to no-display
What this tells me:
  1. It is the fault of the profile views
Next failed step:
  1. Change profile view styles around, including to a NO DISPLAY.
  2. Removing all bands
So, any ideas?
Todd
Todd Wilkinson, P.E.
2 REPLIES 2
Jeff_M
in reply to: twilkinson
I saw something similar to this once. Turn on all of the profileview styles display properties. The other time I saw this there was a text component way off in space that took some doing to locate. If you still can't find it, feel free to post, or place it in a dropbox location and give a link to it here.
Jeff_M, also a frequent Swamper
twilkinson
in reply to: Jeff_M
Thanks, I'll give it a shot.
Rail Community
