- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
For those familiar with Alignments and Design Standards files related directly to superelevation calculations and including spiral lengths and transition lengths, this is a topic for you!
The situation I have is that while I've created a clear Design Standards file based on my jurisdiction. Once I calculate the superelevation I was hoping to see the transition lengths that are standard applied to the superelevation calculations after the wizard does it's things. Now for whatever all the key stations that are assigned by Civil 3D default are all set to be the Start and End of the spiral-in and spiral-out. Why, I have no idea since this should be based on the transition length.
I'm pretty sure this isn't how road / highway design is supposed to be intended since we apparently need to adjust all the key stations in superelevation tables to match what is "required" based on the standard transition length. If a spiral is set to 100m and the transition standard is set at 190m. The transition in and out regions should be based on the transition length and NOT the spiral length.
I'm hoping I'm missing a setting and that Civil 3D isn't built this way by accident. I'm fairly supprised the highway designers haven't come across this and posted anything within the Autodesk Community. Any assistance on procedure changes to get this to work "properly" would be greatly appreciated.
