Civil 3D Forum
Alignment stations end in middle of line
2 REPLIES 2
678 Views, 2 Replies
I have a centerline alignment for a waterline, and recently edited it using basic geometry editor tools to adjust the alignment position.  After making the changes, I noticed the existing surface profiles are ending at about 592 feet from the beginning of the alignment instead of the `6000 foot total alignment length.  I checked the alignment properties, and it does indeed say it's 592 feet long, but the line drawn directly over it is over 6000 feet, as it should be.  I ran an inquiry and it shows stations from 0+00 to 5+92, then after that doesn't show any stations.  The alignment itself, when clicked on, does run the entire length, it just doesn't show that in the properties.  The referenced surface overlays the entire alignment, and the alignment is a single line without any overlaps, etc.  I already tried running audit and restarting, but no luck.  Units are also correct.  Any ideas?
2 REPLIES 2
Jeew-m
Dear Friend,
In your first image I see that your reference point is at 1+00 instead of 0+00. If you update the reference point the things may be changed.
However I am not sure whether you have a surface profile. If there is a surface profile it should update automatically.
Check your profile whether is static or not. It should be dynamic.
Better to upload a sample dwg or at least a landxml.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
doben
Did you create the alignment from existing geometry?
I've had the same issue editing an alignment created this way, in particular if it has curves.
If that's the case edit the alignment to delete the part where the stations don't show up then add new vertices to re-establish it.
Hope this helps.
Rail Community
