Alignment Station Offset Label
david
david
Moving the text from an Alignment Station Offset Label at a certain point automatically flips the text. (See attached) Is it possible to stop the flip?
tcorey
Edit the label style. On the Dragged State tab, change Display from Stacked Text to As Composed.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
david
Tried your suggestion...Text doesn't flip but the leader arrow still does...
tcorey
They don't give you control over the leader.
Tim Corey
Redding, CA
fcolocho
Good afternoon,
I have a question about alignment offset labels. Please refer to the inset:
I can label offsets (such as top of curb) we created an expression to add to the offset label the elevation of the TC (basically it reads the elevation of the road surface and add 6"). I would like to create a style to label TAG numbers instead, then extract the alignment station, offset and TC elevation from the tag and show the information on a table.  Thanks in advance.
