Alignment Mask Will Not Remove
J-Porter
J-Porter
J-Porter
Well, I posted a video for better understanding, but I'm not sure if it will post.  So, to better explain. . .
I've got an alignment in a drawing that is being shortcutted into another drawing.  In the alignment drawing there was a mask on the alignment.  It has since been removed.  However, when the reference is synchronized the mask will not go away.  I cannot figure out why the mask remains.  Any ideas?
user181
Try going to the Mange tab on the ribbon and select Mange Data Shortcuts (command: _AeccManageDataShortcuts) and select the alignment under Drawing Objects and also on Data Shortcuts and then select the button at the top between the two sides to relink them.
J-Porter
@user181, that worked!!!!  Thank you, thank you, thank you!!!!  I thought I was going crazy.
