I have scoured the web and these forums and I may have just missed this, so I apologize if I have.
Working in Civil 3D 2020.6.2
The jurisdictions we work in require water mains to be stationed in plan view and for horizontal bends to be called out as a fraction of 360deg (for example, 45deg = 1/8 Horizontal Bend (HB), 22.5 deg = 1/16 HB and 11.25deg = 1/32 HB). We have alignments created along the water main and I would like to label the angle with an alignment label (tangent intersection) but the expression to convert does not seem to work.
When I write an expression (called HB CALLOUT in this case) as "360/{Delta Angle}"
It returns the middle line below:
However, the bottom line is another expression called "ANGLE TEST" which is 360*{Delta Angle} and that value is correct (360*45=16,200.00)
Am I doing something wrong? I am pulling my hair out trying to get a 360/45=8 (or any of the others to work for that matter).
Gutschick, Little & Weber, P.A. (GLW)
CADD Manager
Civil 3D 2023.2.1
Windows 10
