Civil 3D Forum
Alignment from object does not display line segments
1 REPLY 1
rstewartKFJTR
115 Views, 1 Reply
     Good morning, I recently created an alignment from a object "Polyline with arcs and line segments" and one of the things that I noticed is that the alignment does not display the line segments after creation, however it only shows the arc segments. I would like to know if anyone has encountered this before and what would be the solution?
Thank you!
1 REPLY 1
user181
in reply to: rstewartKFJTR
Hi @rstewartKFJTR   Select your alignment and then right click and select Edit Alignment Style.  Then in the dialog box go to the Display tab and make sure the light bulb is turn on for the line component so it is visible and also check the layer it is assigned and make sure that layer is not frozen or off in the dwg file.
Rail Community
