Alignment Edit
Alignment Edit
farzad.deldjoui
Alignment Edit
farzad.deldjoui
I need to modify an alignment and create a tangent between reverse curve. please let me know how this can be done.
Jeew-m
For a reverse curve you cannot add a tangent at the middle without changing the curves because reverse curves means 0 tangent length.
To add a tangent you need to change the location of at least one curve.
Delete one curve through geometry editor.
Create that curve again without connect to the other curve.
Then add a free line between two curves.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
lynn_zhang
Hello @farzad.deldjoui ,
Just checking to see if your problem has been solved. Did the response from @Jeew-m help answer your question? If yes, please click on the "Accept as Solution" button in his reply so this helps other users in the community find the solution too. Thanks!
Lynn Zhang
