- Mute
- Permalink
- Report
I need to modify an alignment and create a tangent between reverse curve. please let me know how this can be done.
For a reverse curve you cannot add a tangent at the middle without changing the curves because reverse curves means 0 tangent length.
To add a tangent you need to change the location of at least one curve.
Delete one curve through geometry editor.
Create that curve again without connect to the other curve.
Then add a free line between two curves.
Hello @farzad.deldjoui ,
Just checking to see if your problem has been solved. Did the response from @Jeew-m help answer your question? If yes, please click on the "Accept as Solution" button in his reply so this helps other users in the community find the solution too. Thanks!
