I have a centerline alignment defined from a polyline that starts at the middle of an existing T-intersection and starts with Sta 1+00.
When I draw the existing profile using this alignment I want it to show starting from Sta 0+50, while the plan view maintains a visible centerline starting at 1+00. I can get the grid to display the 'previous' 50 feet easily enough, but not the existing surface line(s).
Is this possible?
Solved by Jeff_M. Go to Solution.
Draw the alignment to be the full length of the desired profile to be shown. you will need this to be able to show PipeNetwork structures which lie on that side of the intersection as well. Then use the Masking tab in the Alignment properties to hide the portion(s) you don't want to see.
Worked great. And good point regarding the pipes. Thanks.
