Aerial Mapping : GeoTIFF to DWG (Import TIFF to AutoCAD)
Message 1 of 13
I have a georeferenced aerial map as a .TIFF image. I want to convert in to a .DWG file, without loosing the georeferenced data of it, so that it can be directly accessed on platforms like AutoCAD or DWG Viewer.
How can I import the .TIFF file of the map on AutoCAD CIvil 3D 2018 and what are the necessary settings to be maintained, so as to keep the properties of the map intact?
How to Save it as .DWG file making it directly accessible for the next person using it?
Please answer this considering me as an absolute noobie to AutoCAD.
THANK YOU
Replies (12)
Message 2 of 13
Neilw_05
Plain Autocad has no ability to understand the meaning of coordinates. If your image has an origin at 0,0 and is 1,000 units x and 1,0000 units y, that is how it will insert into a drawing, regardless of what the units represent. Only vertical applications that support geodetic referencing such as Map or Civil 3D can position an image in a true position relative to the earth. To do so those vertical applications are designed to read correlation data associated with the image files. The correlation data tells the application what coordinates, scale and rotation parameters to apply to the image to make it fit the globe. The correlation data may be embedded in the image attributes or saved in an external correlation file that is read by the software.
Unless you have a vertical product that is capable of reading the correlation data, you are left with manually applying the parameters yourself. This of course requires a thorough understanding of geodyssey.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Message 3 of 13
Jeew-m
Message 4 of 13
Neilw_05
Also, be aware that Autocad does not convert an image when you insert it into a drawing. The image is just a reference to the source file. If the source file is renamed, moved or deleted, Autocad will not be able to display it. Think of it as an XREF. So you do not have to worry about changing the properties of an image when you insert and manipulate it in Autocad. You can move, rotate and scale the image without altering it's properties in the image source file.
WIN 10 64 PRO
Message 5 of 13
I went through this article but I'm not able to get those settings. Can you help out as am using 2018 version?
Message 6 of 13
I'm using CIVIL 3D 2018 . Please help me out with how to use it for this purpose.
Message 7 of 13
Is there any other may to convert a GeoTIFF directly to DWG file ?
Message 8 of 13
Jeew-m
Please follow this.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Message 9 of 13
I've gone through this video too but I'm not able to get the same interface. Screenshot (3).png
Message 10 of 13
Jeew-m
According to the image you are using Autocad 2018. But you asked how to do it on Civil 3D. The video also uses Civil 3D. Not Autocad.
Jeewana Meegahage
Design Engineer
Message 11 of 13
Having trouble inserting a large GeoTIFF into a DWG; any pointers?
Thanks!
Message 12 of 13
Pointdump
Ocean,
Can you expand a little on "having trouble"? Maybe tell us your version/year of C3D, and either post the Tiff or a link to it.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 13 of 13
lim.wendy
Hello, community!
This seemed to be a very popular topic. Although this post should technically be in the AutoCAD board 🙂 , given you can easily achieve this using Civil 3D.
Here's a very good old video posted on YouTube for those who want to do it in plain AutoCAD, provided you have the associated world file (jgw, tfw, etc). Enjoy!
If the suggestions helped you, please hit the "Accept Solution" button, as it helps makes the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you. 🙂
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
