Aerial displays faded in layout viewport, but prints unfaded.
BWYarger
BWYarger
I have a background aerial that shows fine in the model tab, but displays faded in the layout tab viewport.  The layout plots without fading.  How do I get the display to show not faded?  I have clipped the two images that make up the background aerial.
Brad
LT, C3D 2005 - 2026
Windows XP, Vista, 7, 10, 11
ChicagoLooper
Hello @BWYarger
There could be a number of reasons why the images look faded on a layout but look OK in model and are OK when you print. It could also be two or more things occurring simultaneously.
  • How did you 'add' the images to modelspace? What command or procedure did you use?
  • Did you add the image to another drawing then add that drawing as an xref to your working drawing?
  • What are the properties shown in the properties palette when an image is selected?
  • What format is the image? jpeg? tif? png? or something else?
  • Is TRANSPARENCYDISPAY=0?
  • Is XDWGFADECTL=0?
  • Etc. etc., etc.
Chicagolooper
BWYarger
I just looked again, and it isn't faded, it is a negative of the image in the layouts.  I have five and all are displaying the same.
Aerials inserted using Mappiinsert to the current working drawing.
Properties shows:
Color: Bylayer
Layer: Airphoto
Linetype: Bylayer
Linetype Scale: 1
Lineweight: Bylayer
Transparency: 0
Hyperlink:
Image Adjust
Brightness: 50
Contrast: 50
Fade: 0
Geometry
X: 4940000
Y: 3815000
Z: 0
Rotation: 90d (north is up)
Width: 5000
Height: 5000
Scale: 1
Path: S:\Projectnumber\Photos\Airphotos\N109E233-2020.tif
Show Image: Yes
Show Clipped: Yes
Background Transparency: No
Transparency Color:
XDWGFADECTL = 0
UCS = World in both
Plan - World
Brad
LT, C3D 2005 - 2026
BWYarger
It has something to do with the images being clipped because the problem went away when I turned off the clipping.  They are too large to work with if not clipped, but I can do small edits that I need to see the image and then turn the clipping back on.
Brad
LT, C3D 2005 - 2026
ChicagoLooper
What's the image format?
Black & white or color?
Chicagolooper
BWYarger
It is a color airphoto in geotiff format.
Brad
LT, C3D 2005 - 2026
