AECC COGO POINTS
AECC COGO POINTS
Up until about a week ago, I have been able to select points and then modify attributes (Northing, Easting, Elevations, etc..) in the properties dialog box. Currently the attributes are blank, do not display, nada.  Is there a setting or variable that is not set correctly? How do I fix this issue?
Replies (16)
Pointdump
David,
Maybe it could be <<<This>>>.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Thank you Pointdump,
I had already tried unlocking and then updating and refreshing the points without any change.
See Image below, I am attempting to attach a screenshot.  This is frustrating.
2017-12-10 21_44_25-Autodesk AutoCAD Civil 3D 2018 - [holfelner PlotPlan.dwg].png
Jeew-m
Dear Friend,
These points seem to autocad points or land desktop points. Not cogo points.
Hope this will help you.
http://blogs.rand.com/civil/2017/10/aecc-points.html
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Jeew-M,
That doesn't seem to be the issue either.
Thank you.
Mike.M.Carlson
Hello-
@Jeew-m is correct.  You have selected a legacy soft desk or LDD point in the pic you shared.  Simply go to your Home tab\Points drop down and select convert softdesk points.  Once you perform this conversion to Civil 3D COGO points, you will be able to edit them in the Properties window.
I hope this helps.
Michael M. Carlson
Senior Civil Designer
CADD Manager
AutoCAD Civil 3D Professional
AutoCAD Professional
Mr. Carlson,
These were imported from a csv file in to Civil3d 2018. I have tried to convert from LDD, Softdesk, and AutoCAD points with the reply "invalid selection set."  I am curious as to why/how Civil3d would import to a legacy format? I appreciate your help.
Mike.M.Carlson
hmmm....this is strange.  Have you installed latest 2018 Service Pack?
Another option.  Create a Survey Database and create new Import Survey Event.  Import the point file into the Survey Database and insert into the drawing.  These points will be locked in the dwg, but at least you can edit them in the Survey Database followed by a point update, so the point changes are shown the dwg.
I hope this helps.
Michael M. Carlson
CADD Manager
Pointdump
David,
Please post your drawing and the CSV file.
Dave
Dave Stoll
Las Vegas, Nevada
Please find them attached. FYI this is happening in every drawing, it is not isolated.
Jeew-m
I can't see anything wrong here. Everything OK for me. can change the attributes. Even can load the csv and make edits.
Jeewana Meegahage
Design Engineer
Thank you everyone. I believe I have it figured out. One of the updates, I think an object enabler, actually caused the issue. I have uninstalled a couple of them and I am back to normal. Once I figure out which one it was I will post.
AllenJessup
Is it possible the points were imported over old points. An AECC COGO POINT is definitely not a current point object, unless things have changed in 2018. We're still on 2017. I couldn't check the drawing because of that.
Allen Jessup
CAD Manager - Designer
BushW
Hello @Anonymous
Please reply back once you figure out which object enabler you had to uninstall because I didn't see any issue with the points in your drawing. The points in the drawing matched the points in your .csv points file.
Wendell
Wendell Bush
Civil Infrastructure Technical Support Specialist
BushW
Hello @Anonymous
I just wanted to follow up here, any progress on this issue?
Best Regards,
Wendell
Wendell Bush
After uninstalling the Object Enabler. the problem was fixed. I have been unable to identify/find the specific Enabler.
This is helpful thank you
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
