adding text field values
hyunmyeongg
Message 1 of 11
hyunmyeongg
So I am using multileader for quantities pointing out for line work. and multileader pointing at two separated objects and I used ctrl+F for putting field in the text to take length of the object. but I realized I cannot select more than one object to put the field link.
Is there way I can put 2 objects in one field or add up two field values and put it in one?
Replies (10)
Message 2 of 11
tcorey
This is where automation through programming comes in. AutoLISP, .NET, etc.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 11
Topmig
hi @hyunmyeongg ,
Can't you add 2 fields, or several ones,  in your multileader, identifying with a text what you are measuring?
Can you attach some images or dwg to understand what's your purpose.
Message 4 of 11
MMcCall402
Enter the field value as a Formula.  You can define the formula by using more fields, to more than one object, and perform functions with those values.image.png
Mark Mccall
CAD Mangler
VHB - Vanasse Hangen Brustlin, Inc.
Linkedin
Message 5 of 11
hyunmyeongg
so I want to combine those two remove c&g quantities.
Message 6 of 11
hyunmyeongg
I'm not quite familiar with using that formula section.
seems like I have to type the values manually, I don't see any merit of using field anymore since I can just use calculator and put the number down by using regular text.
I am using field so I can minimize human error by putting wrong numbers. but if you manually put the numbers, I really don't see why using field
Message 7 of 11
MMcCall402
The field category is Objects
The field name is Formula
In the Formula: area choose Insert Field from the menu when you right click in the formula area.  You can do this more than once in this area to access values from as many objects as you need.
Mark Mccall
CAD Mangler
Linkedin
Message 8 of 11
MMcCall402
The values in the formula example and Fields, not manually entered values.
The process is making a field that uses a formula with values derived by fields to gather live values from the objects. Fields within fields.
Mark Mccall
CAD Mangler
Linkedin
Message 9 of 11
Topmig
HI @hyunmyeongg ,
Use "multileader" and "insert field" like @MMcCall402  said to use a formula, or use it separately.
You can add as many arrows as you like in multileader.
Message 10 of 11
hyunmyeongg
I just realized that field value is not dynamic to the selected object.
Is there any way i can make it dynamic? or is that going to be creating label dedicated to the object?
Message 11 of 11
MMcCall402
Regen and the value should update.
Mark Mccall
CAD Mangler
Linkedin
