Adding Civil 3D objects - Arch Pipe
Message 1 of 10
Hello, I am working on a project where we need to have Arch Pipes, which we don't have in our part catalog. Is there a place where I can download additional parts for our part catalog? I know I could create the part in part builder myself, but am looking to save some time.
Thanks!
Replies (9)
Message 2 of 10
See if this video helps https://www.youtube.com/watch?v=tQjQYuSeg0o
Message 3 of 10
ChrisRS
@Anonymous, If you are talking about pipe network parts, and the concrete arch pipes available do not suffice, part builder is you only choice. I find no additional content on line.
These links might help with part builder: A Successful Adventure Building Arch Pipe with Pares Builder and Arch Pipe Within Part Builder (this one be a dead end)
If the corridor solution that @Anonymous suggests will work for you, a PKT file for a structural plate arch subassembly is available with Civil 3D 2018.2. I think this is also in a Civil 3D 2017 enhancement pack. This is probably not the arch pipe you are looking for, but since it is provided as a PKT file, you have the source to use it as a starting point and modify as appropriate.  Link: New Features in Civil 3D 2018.2
Christopher Stevens
Message 4 of 10
eweakleyNHNFN
Video is private, can't view it.
Can you make it viewable?
Message 5 of 10
brian.strandberg
There are a bunch of arch pipes in the standard Autodesk Pipe Catalog, you may not have them in your part list.  Editing a sample part list here:
Add pipe width and Height. You can use the 'add all sizes' checkboxl.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
Message 6 of 10
tlohrmanUEDVY
Am I the only one that needs Corrugated Metal Pipe Arches? I don't want a concrete arch, I want a metal arch. Do I need to go through Part Builder and create some of my own?
Thank you,
Tom
Message 7 of 10
admin89MEZ
im facing the same issue if you found a solution let me know
Message 8 of 10
eweakleyNHNFN
Go to Red Transit website:
https://www.bing.com/ck/a?!&&p=8b2b393e5f6b50691e8d91bfd0cfebb014eff362564c9f797b5d0cda0a0c1dfaJmltd...
download (arch piep library for free) then install per instruction they give. They also have a video easy.
Message 9 of 10
tlohrmanUEDVY
That is AWESOME! Thank you!
Message 10 of 10
peterl39TFV
Observer
Observer
LFG thank you Red Transit people!!!
